Tps voltage slowly dropping
Old Sep 13, 2016 | 11:55 AM
Infiniti9189's Avatar
Infiniti9189
Default Tps voltage slowly dropping
First off i own a 2001 dodge 1500 5.2, So i keep looking everywhere and cannot seem to find someone with the same issue, my tps voltage seems low even a brand new one, around 3.7 at WOT, however after a month or two after replacment the WOT voltage drops to around 3.2 or so. Why am i not getting more so around 4.5 volts at WOT? Also im getting about 8-9mpg per tank(city/highway) sluggish performance until about 3000 rpm then it feels like i hit the powerband in a 2-stroke dirtbike. Has trouble mintaining speeds up inclines in overdrive on the highway. I hear a "sucking noise" like a vaccuum leak on cold startup, goes away after warms up and disappears upon acceperation while cold. I am thinking of removing forward o2 sensor and driving to see if the cat is clogged and i want to replace spark plugs with better ones. My muffler is currently cut off so i have cats only. Maybe im losing back pressure along with the ****ty stock 3.55 gears(want to change to 4.10s when funds available) can anyone shed some light on my issues or point me in some tood directions.
Old Sep 13, 2016 | 05:52 PM
Moparite's Avatar
Moparite
Did you happen to test the supply voltage? What brand sensor? Do you have any codes?
Old Sep 13, 2016 | 09:37 PM
Infiniti9189
Im sorry to sound like a noob but would i trace the 5volt wire back to the pcm and test it there?
Old Sep 13, 2016 | 09:48 PM
Infiniti9189
Sorry yes i did test supply its getting about 5.12 volts, im pretty sure at one point i had a tps low voltage code and i have tried a few different sensors, one from advance auto and one from o'reileys whatever their brands are.
Old Sep 13, 2016 | 09:51 PM
Need to see if source voltage is bleeding off, causing sensor return voltage to also fall off.
That's a strange one though...... does it do that at idle?? Or only with the throttle open to some degree?
