2000 Dodge Ram 4x4 1500 steering oddity
Old Sep 16, 2016 | 01:32 PM
ccd1977's Avatar
ccd1977
Default 2000 Dodge Ram 4x4 1500 steering oddity
Whenever I turn sharply, my truck feels like its on warped wheels? Like its rocking. I am in N and not 4L or 4H.
Everything is fine with mild turning or going straight. Have not noticed it in reverse either. All fluids are good.
Any ideas?
Old Sep 16, 2016 | 05:42 PM
2bit's Avatar
2bit
It's probably axle shaft u-joints getting dry and starting to seize up.
Old Sep 16, 2016 | 06:40 PM
With the t-case in neutral, I do believe the front and rear axles are still locked together.
Old Sep 19, 2016 | 12:19 PM
ccd1977's Avatar
ccd1977
Default Tcase
So Should I put it into 2H for hwy and city driving?
Old Sep 19, 2016 | 12:23 PM
Yes. Do NOT use 4x4 on high traction surfaces, you will break things.
Old Sep 19, 2016 | 12:33 PM
ccd1977's Avatar
ccd1977
So is N considered 4WD?
Old Sep 19, 2016 | 12:43 PM
ccd1977's Avatar
ccd1977
What is the difference between 2h and N?
Old Sep 19, 2016 | 01:45 PM
N is neutral, it disengages the t-case from the trans. (or, alternatively, the trans from the rest of the driveline.) I do believe that front and rear axles are still locked together though...... so, you can't simply drop the t-case into neutral and flat-tow the truck. (I think, not 100% sure on that.....)
2hi only uses the rear driveline to move the truck. Front is completely disengaged. No power is transmitted to the front driveshaft.
Old Sep 19, 2016 | 02:06 PM
ccd1977's Avatar
ccd1977
OK. I am going to shift it into 2H then. Never knew I needed to do that for driving. Its always been in N. I am such a noob
Old Sep 19, 2016 | 02:33 PM
It shouldn't move at all in neutral...... the trans should be disengaged from the rest of the driveline....... I would be tempted to check the tag on your t-case, and see what year it was made.... shift patterns changed in 98, it's entirely possible that neutral on yours, really isn't.
