Heavy Duty Service Group
Alright the heavy duty service groups contains:
136 amp alternator, 750 amp battery, heavy duty engine cooling, auxiliary oil tranny cooler, and transferase skid plate.
My radiator is going, and I want to keep the heavy duty cooling anyone know what radiator they used for these? or where I can find out?
Only one radiator for the v6 up to the 360 regardless of HD service . Single row 1.250". If you are planing on buying one i would suggest radiator.com they offer a lifetime warranty where the local stores only offer a year. I went threw two of them in two years so i learned my lesson. The one from radiator.com has been in for ten years.
If you plan to keep the truck for awhile, see if you can find an all-aluminum radiator, such as CSF 2969. This radiator will last a very long time, as there are no plastic tanks, which is a common failure point of the OEM radiator. CSF 2969 is also a perfect bolt-in swap. For more information, take a look at this thread:
https://dodgeforum.com/forum/2nd-gen...-radiator.html
At one time, this all-aluminum radiator was getting hard to find, however, it appears that CSF is continuing to make them again. Amazon and several other outlets appear to have them available.
