Hello
I have a 1997 dodge ram 1500 4x4 5.9 360 it's got a 3 inch body lift with a 6 inch suspension lift with 37 inch grip tires on 17 inch rims and it's a standard transmission I broke my front yoke on my rear drive shaft and I need to find out what kind of Manuel transmission I might have
Welcome to DF.
You likely have a NV4500 trans, since you have the 5.9.... however, the rear driveshaft plugs into the transfer case, which, on a half ton, will be an NV231D (or possibly DHD)
Not that it really matters, I do believe that all of them have the same output shaft size, and spline count, except maybe the diesel trucks, or V-10s.... Have you tried local junkyards, see if you can just get the whole driveshaft?
Yes I have checked local junk yards but one junk yard may have it but he's got every drive shaft sitting on top each other from other trucks all mixed up like finding needle in hay stack I got my drive shaft and broken yoke at drive line USA he said could take up to 3 weeks he has to find out what kind of trany I had but I. Gana right it down and give him phone call In the morning
