46re overdrive reluctance/noise
Old Oct 19, 2016 | 02:59 PM
Pairof99s's Avatar
Pairof99s
Default 46re overdrive reluctance/noise
Hey guys. So I searched a couple pages on different search terms for this, didn't find any other applicable threads, so I'm making my own. My truck is in my sig, a 99 1500 360 mag 4x4.
So my issue is, when I'm cruising along in overdrive, if I put my foot in it a bit to speed up, my rpms drop to like 1100-1400 ish and it sits there, with a definite almost grinding noise that I can feel in the pedal. I gotta put my foot way in it to about 60-75% throttle to get it to do anything, at which point it downshifts twice into 2nd, then usually up into 3rd in a few seconds. It's started in the last say 4 or 5 months. Obviously first thing is to do a trans tune up/solenoid fluid filter replacement, since I haven't done it in the 8 months I've had it but I wanted to see if there was some insight and knowledge I could pull from you guys first.
Any ideas/thoughts/anything is appreciated guys, thanks.
Old Oct 19, 2016 | 06:35 PM
That doesn't sound right..... RPM should NOT drop when you press the pedal.... Unless there is something else going on in there, not related to the trans. Possibly bad TPS??
Adjust the bands while you have the trans open.
Check adjustment of the TV cable as well...... might wanna tighten it up a notch or two.
Welcome to DF!
Old Oct 19, 2016 | 10:25 PM
Pairof99s's Avatar
Pairof99s
You know what, while I dismissed the TPS at first, now that I think about it you might have something. Specifically, it surges up a couple hundred, then drops. So if I'm coasting at say 1300 and give it mild throttle, it'll go up to 1500 then drop right away to 1100-1200, and stay there with that grindy noise until I hit higher throttle, then it does the shifting. So since I have my gf's truck pulled apart, I'll swap her TPS onto mine to see if there's a difference, because hers definitely didn't do this before I yanked it apart.
I also noodled around with my TV cable for a week or so last month, moved it in, out, too far in, all kinds of stuff. Nothing felt right so I put it at stock setting.
Old Oct 20, 2016 | 09:40 AM
The 200 or so RPM change is TCC locking/unlocking. If it makes rude noises when it locks..... you either have a failing torque converter, or, inadequate pressure to get it to lock up.
Old Oct 20, 2016 | 11:00 AM
dbbd1's Avatar
dbbd1
^ that's what I thought. Sounded like my converter did.
