lift kit
Old Oct 29, 2016 | 12:59 PM
David Clauder's Avatar
David Clauder
Default lift kit
I have a 3" lifted coil spring in front with a 2" spacer and a 3" block in the rear. I want to raise it up an inch to 5" all around. Anybody know a good company that I can go through for the parts
Old Oct 30, 2016 | 10:35 AM
top guns customz. Check 'em out.
Old Oct 31, 2016 | 07:43 PM
David Clauder
I put the 3" lifted coils in and put the 2" coils spacers back in and I still didn't get it where I wanted it so I'm trying to get in touch with skyjacker to figure out what the deal is.. these r the after pictures...
David Clauder
I want about an other 1/2" or so. Just to bulldog it some
Old Nov 2, 2016 | 03:29 PM
Mopar4x402's Avatar
Mopar4x402
Default 02 Ram
I got a 2002 dodge ram 1500 4x4 with the 5.9, rcsb. Will 35x12.50r17 fit with a 3in leveling kit? Thanks in advance.
Old Nov 2, 2016 | 03:44 PM
You know that does horrible things to you caster angle.......
Old Nov 2, 2016 | 03:45 PM
Wrong forum. You have a third gen Ram.
Old Nov 2, 2016 | 07:02 PM
David Clauder
I have an 01. And what's the caster angle. Instead of doing that I just decided to go from 3" to 4 or 5" and not bulldog it but instead of buying a professional kit for 800 would anyone know where I can just get the rear spacers and new u bolts for rear and new springs and control arms for the front for a decent price? I've got the sway bar drop down brackets that I was gonna put in but these 3" lifted coils didn't do what they were supposed to and I wasted $200 on em
Old Nov 2, 2016 | 11:02 PM
Going over three inches of lift, you need to address the control arms, and track bar, to keep the front axle centered in the front of the truck, and in the wheel wells. Just adding the lift will make it dangerous to drive. I am also not a fan of stacking blocks in the rear, even though multiple companies offer kits that do exactly that. I have been taught for decades that stacking blocks is just a bad idea.
Instead of just piecing it together, you are MUCH better off actually spending the money, and getting a kit, that has been engineered to work properly. Unless you have a VERY good idea of what you are doing, a kit is the ONLY way you should go.
Caster angle is the angle between a vertical line, and a line that goes thru the center of both ball joints. Caster is what cause your trucks steering to want to self center. Also helps it want to keep going straight down the road. Inadequate caster can make the truck rather challenging to drive.......
Old Nov 3, 2016 | 12:14 AM
dbbd1's Avatar
dbbd1
I agree, anything over the factory blocks, I would go with add-a-leaf. Stacking blocks leads to your axle twisting and more.
