Which gears?
Old Oct 30, 2016 | 01:59 PM
44dakota's Avatar
44dakota
defiantly 4.56 gears with 33s, at 60 mph you'll be at 1900 rpm in O.D which is perfect..
Old Oct 30, 2016 | 07:13 PM
97ramrod1500's Avatar
97ramrod1500
Alright you guys talked me into it; 4.56 gears it is! But not till next year. I will definitely be doing the regear before I step up to 35s.
Old Oct 31, 2016 | 01:47 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
If you are going to go to 35" tires then you need to go deeper than 4.56 gears.
Here is the best gear calculator I've found. http://www.grimmjeeper.com/gears.html
Use the pull down menu to find your tranny and transfer case and then put in tire size and gear ratio.
Old Oct 31, 2016 | 03:53 PM
44dakota's Avatar
44dakota
I missed that part were you said your eventually going to 35s..in that case, id go 4.88 gears, and I think that as steep as you can go with a Chrysler 9.25...
Old Oct 31, 2016 | 07:55 PM
97ramrod1500
With 4.56 gears at 75 mph I'd be humming at a little over 2200rpm with 35s. That's right about where I'd like it to be. I think 4.88s would be screaming a little much. I don't need a speed demon; just not a turd with these 3.55 gears. Wouldn't be so bad if these trucks were making 400+ hp. My Pontiac will roast tires all day with the 3.23 gears on there but not so much with these trucks.
Old Oct 31, 2016 | 10:23 PM
Wildman4x4nut
Veteran: Army
4.88 gears & 35" tires puts you at 2400 RPM's which would be fine for cruising down the highway. Where it really helps you out is when taking off from a stop. Also it will save your tranny trying to move those large tires. But it's your truck so do as you wish.
Old Nov 1, 2016 | 01:29 PM
nicraage's Avatar
nicraage
When I had my 35's I could cruise at 90-100, and be about 2600 rpm in my modded 318. I wouldn't worry about not having highway speed.
