Heater system
Old Oct 31, 2016 | 07:50 PM
David Clauder's Avatar
David Clauder
Default Heater system
Trying to get my truck ready for winter.....warmed the engine up and started the heater. Nothing but room temperature pouring out of it. Its not leaking on the floorboard when the thermostat opens so I know it's not cracked(dealt with that on another truck in the past). I've seen videos of flushing the core out in reverse of normal flow and it in clogs it. By then my dad who is a Ford owner for years and taught me to be the hobby mechanic I am said there's a valve that u can open and close to bypass the core but didn't know if dodge has that or not. Any input would be appreciated
Old Oct 31, 2016 | 07:53 PM
AtomicDog's Avatar
AtomicDog
Most likely this is your issue: http://www.heatertreater.net/magento...ram-95-02.html
I bought one for my truck, but just need to take the time to install it.
Old Nov 1, 2016 | 06:42 AM
Moparite's Avatar
Moparite
Truck info might help, The link above works on the newer rams without a cable operated blend door.
Old Nov 1, 2016 | 10:41 AM
No diverter valve on the dodge heater core. It is a constant flow system.
Old Nov 1, 2016 | 05:10 PM
David Clauder
I didn't think people came into this forum with a newer ram. Ita an 01 ram 5.2
Old Nov 1, 2016 | 06:37 PM
Moparite's Avatar
Moparite
Newer meaning 98 and up. That's when i think they stopped using the cable to adjust heat.
Old Nov 1, 2016 | 07:22 PM
David Clauder
/so does that mean the heater treater will work on my truck?
Old Nov 1, 2016 | 08:33 PM
AtomicDog's Avatar
AtomicDog
You should check yours to ensure its broken, but its highly likely.
According to the web page noted above, 2nd gen trucks from 1995 - 2001 use the electronic style motor to operate the blend door in lieu of the cable that was in earlier year trucks.
Old Nov 2, 2016 | 08:59 AM
It was cable operated thru 99, 00 and up trucks got the little electric motor.
Easy to see which system you have, just to be sure. Take a look under the dash at the heater box. If there is a little box just to the passenger side of the trans tunnel, that's for the temp door. No little box means cable operated.
Old Nov 2, 2016 | 09:30 AM
dbbd1's Avatar
dbbd1
My 99 has the electric motor.
