Upgrading Radiator
Old Jun 16, 2017 | 11:33 AM
renardk764's Avatar
renardk764
Originally Posted by 94Beater
Too much stuff to upgrade. Hoses, adapters, Shroud is a big one.
You better spend you money on this
http://www.ebay.com/itm/3-Rows-1994-...3D321970009350
that is what I did. Otherwise you'll spend more.
How is this working for you?
Old Jun 16, 2017 | 07:30 PM
AtomicDog's Avatar
AtomicDog
I'm running a CSF 2969 all-aluminum radiator in my truck. It's an exact bolt-in fit and works perfectly. it should be available thru Amazon.com
Old Jun 17, 2017 | 09:03 AM
renardk764's Avatar
renardk764
Unfortunately the CSF 2969 has been discontinued and the part number that CSF has now appears to be for the Ram Van. I've been searching like crazy. LOL
Old Jun 17, 2017 | 09:25 AM
AtomicDog's Avatar
AtomicDog
That's not what I'm seeing for this listing -
Amazon Amazon
- you can always try contracting the Amazon seller to verify it or just order it and see what happens if you have the time. I went through the same search recently for a friend of mine and we were pleasantly surprised when the correct radiator showed up at his door.
Old Jun 18, 2017 | 08:01 AM
renardk764's Avatar
renardk764
That's not what I'm seeing for this listing - https://www.amazon.com/CSF-2969-Radiator/dp/B001FHDXOC - you can always try contracting the Amazon seller to verify it or just order it and see what happens if you have the time. I went through the same search recently for a friend of mine and we were pleasantly surprised when the correct radiator showed up at his door.
Cool. I'll check it out
