Upgrading Radiator
Old Nov 5, 2016 | 02:26 PM
precisionhomeinspections's Avatar
Default Upgrading Radiator
Hello Folks! I need Your Help and Expertise. I want to Upgrade My Radiator in My 1998 Dodge Ram 1500 5.9L 2WD Sport EXT. CAB 1 Row To A Radiator from a 1998 Dodge Ram 3500 V-10 8.0L Gas 2 Row?! Thanks Sincerely:
Old Nov 5, 2016 | 09:32 PM
Think I have seen this elsewhere... So, I will tell ya the same thing here, I told ya there, you will need adapters for the hoses, as the inlet/outlet on the V-10 radiator are larger than the V-8 fellers.
Old Nov 5, 2016 | 10:03 PM
AtomicDog's Avatar
AtomicDog
The V10 radiator should bolt into the same space as the V8 radiator or is the radiator support setup different on the V10 trucks??
Old Nov 5, 2016 | 10:28 PM
I think they are both exactly the same. (radiator supports) This came up in another thread not so very long ago. (that's why I know the inlet/outlet are different size. )
Old Nov 6, 2016 | 06:35 PM
I want to Give Thanks to all response to My Post. "God Bless". Sincerely:
Old Nov 6, 2016 | 08:08 PM
Spillage's Avatar
Spillage
There is a second set of holes in the support for the V10 radiator... it's a little wider.
Old Nov 6, 2016 | 08:43 PM
dbbd1's Avatar
dbbd1
What's the name of that company that will make temp port adapter for our radiator hoses? They probably can make those adapters.
Old Nov 7, 2016 | 06:27 PM
94Beater's Avatar
94Beater
Too much stuff to upgrade. Hoses, adapters, Shroud is a big one.
You better spend you money on this
http://www.ebay.com/itm/3-Rows-1994-2001-DODGE-RAM-TRUCK-PICKUP-GAS-ENGINES-aluminum-radiator/201119617444?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D40146%26meid%3D6407cddaf3db4988a578229c61b771cb%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D321970009350that is what I did. Otherwise you'll spend more.
Old Nov 7, 2016 | 08:26 PM
AtomicDog's Avatar
AtomicDog
Very nice. Thanks for sharing.
Was this a direct bolt-in swap for the factory radiator? Did you have to perform any modifications?
Old Nov 7, 2016 | 11:44 PM
94Beater's Avatar
94Beater
Direct bolt on. No other mods. Everything else fits great.
