2001 1500 sport 2WD Wheel Breaing
Old Nov 8, 2016 | 02:56 PM
dpalo's Avatar
dpalo
Default 2001 1500 sport 2WD Wheel Breaing
Does anyone know if the 2nd gen 1500 sports have a removable wheel bearing or do i have to replace the entire hub assembly?
When i go over any bumps with the windows down i hear kind of a klank sound, i have checked and replaced most of the front end it only does it on the front.
Old Nov 8, 2016 | 02:58 PM
01 will be hub/bearing assembly.
Old Nov 8, 2016 | 03:00 PM
dpalo's Avatar
dpalo
damn lol at least they are fairly cheap. do you think thats the noise i am hearing? i didnt hear it much but its gotten where if im going around 20mph i hear or if im doing 50 it doesnt seem to matter
Old Nov 8, 2016 | 05:45 PM
dbbd1's Avatar
dbbd1
Have you checked the track bar joints? Steering components? Shocks?
Old Nov 8, 2016 | 05:53 PM
dpalo's Avatar
dpalo
yes i have all good and i have already replaced everything in the steering except for the idler arm (plan on that this weekend) damn i did not check the track bar purely because i have never heard a track bar make this sound but ill check it out after work
Old Nov 8, 2016 | 06:13 PM
Dodgevity's Avatar
Dodgevity
Wheel bearings don't clunk. They make a howling sound at speed. What you described sounds like sway bar end links and/or ball joints.
Old Nov 9, 2016 | 09:11 AM
dpalo's Avatar
dpalo
thanks i did a visual check and the sway bar links look good and the bushings are still intact but ill pull the wheel off and check both this weekend
Old Nov 9, 2016 | 09:28 AM
Check the shock bolts too.... The lower bolt gets torqued to some truly stupid number, else it rattles over bumps.
