1999 2500 4x4 5.9gas transmission upgrade
Old Nov 15, 2016 | 12:53 PM
Zack Carpenter's Avatar
Zack Carpenter
Default 1999 2500 4x4 5.9gas transmission upgrade
Hey just bought the truck and it has a bad automatic transmission. It slips and barely works in every gear. Everyone wants $2500 to rebuild. I've never had a transmission apart, but I want to and will be doing so by myself. I'm a machinist so it should be doable. What is the best rebuild kit and or BEEFED UP parts I need? Great thanks and appreciation friends!
Old Nov 15, 2016 | 06:09 PM
dbbd1's Avatar
dbbd1
Patc.com and can't remember the name for the kit that allows the pump to pump in "park" not just neutral and drive.
Old Nov 15, 2016 | 06:13 PM
I think all of the kits from PATC will charge the torque converter in park. (letting you check fluid level in park....) Which one you get, just depends on how beefy you want, and your budget. Buying parts, and doing it yourself is certainly cheaper than outright buying the trans.
There are some REALLY good walkthrus for rebuilding the 46RE trans, check in the FAQ/DIY section for some links.
Old Nov 15, 2016 | 07:24 PM
dbbd1's Avatar
dbbd1
Found it!
Sonnax SureCure.
Old Nov 18, 2016 | 08:28 PM
44dakota's Avatar
44dakota
if you want to rebuild it yourself, this is the guy to watch, he goes over very nut and bolt in full detail, breaks it all down into sections for the 46re..
Old Nov 18, 2016 | 11:57 PM
beeker's Avatar
beeker
Funny thing I found out recently, most transmission shops only pull and swap transmissions, they don't rebuild em in house. That's done at TRC distribution centers.
Old Nov 19, 2016 | 12:53 AM
getdown78's Avatar
getdown78
I pulled mine in 2007 and took it to a friend that had a trans shop and he built it for $750 with new conv ! Got about 10k on it and have no probs with it since !
Old Nov 19, 2016 | 11:40 AM
Moparite's Avatar
Moparite
Look at the different kits that patc has, The mega viper i believe is the top of the line. Would definitely get rid of the plastic servo pistons. I noticed that they have 10% off sale till the 21st so now is the time to get it.
https://transmissioncenter.net/product-category/dodge/
Old Nov 19, 2016 | 11:47 AM
Alex Andrew Orndorff's Avatar
http://www.jeepforum.com/forum/f13/46re-tutorial-911009/index2.html#/topics/911009?page=2&_k=3mmmv3
This link on this keep forum is for a 46re rebuild. I assume you probably have a 47re? I'm not sure. Maybe I didn't read your post correctly. But it's pretty much the same from what I've been told. If so, this is a good assembly guide
Old Nov 19, 2016 | 09:07 PM
He has the 5.9 gas, so, yep, 46RE.
