Multiple Electrical issues
Looks like the Radio gets power from a couple different sources......
Fuse 1 in the PDC, (under the hood) That feller is 50 amps...... and supplies fuse 17 in the fuse block on the side of the dash. (which then runs to the radio.)
Fuse 3 goes to the ignition switch..... and then via fuse 7, to the radio. There's at least one more, (fuse 13) that supplies power for the illumination on the radio.
Then I decided to check for power. The radio has 4 power inputs or something like that, or at least the reading I got. Here's a picture of the service manual with al, the radio power inputs.
So I checked if those lined up with what I have on my pin inputs.
They I do get power through all those, pin 7 I get all time power for radio memory. Pin 6 is hot In the ACC. Or run position on the key. And pins 5 and 4 are hot with the headlamps switch on. There seem to be two for the headlamps because of the two positions on the switch, park lights and head lamps.
So I seem to be getting all the power I should be. The other black connector for the radio is all wires for the speakers, and 2 pins on the grey are for speakers. There is however no #1 pin in the grey connector, and I don't see any #1 in the service manual either. There is all 7 pins in the black connector. So does that mean I have the priemium stereo radio? I have the infinity sound system in the truck?
I'm not sure where to go from here. I have power and ground. Would there be anything I'm missing?
Yeah, infinity IS the premium sound system.
The front speakers have amps on the speakers, not sure if the rears do as well, so, they need power for those.
Apparently, the rears have amps as well???? Wiring diagram is just a bit hard to decipher, but, they have power running to them for amps.....
Verify that you are getting power OUT to the amps on C230, pin 1. (dark green, with red trace.)
Still haven't had any sign of life with the display.
229 and 230 are both black...... and both 7 pin..... Well, that makes life fun..... The wire on C230 Pin 1 should be Orange with a red trace.
I have power where i should, and I have ground. That's all checked and done. Grounds through a strap at the back of the radio, just bolts on, and then gets power through 4 different pins. Main comes through pin 6 on c229.
What I don't understand is this:
In this picture, you see two pins leading off the radio labeled c229. The other 4 pins on c 229 are the 4 power pins. Ok so that linds up. But then there are only 3 c230 pins, and then 4 c330. Is c230 for the amps, and c330 for the speakers, and they decided to Mash it up all into 1 plug?
The wire on c230 says it's a DG RD, guessing Dark green with a red trace, and that's what lines up with my pin one on the connector. I only have 1 pin one and that's on the second connector, no pin 1 on the grey one.
So I plugged my radio back in and I have the little orange leds on the slides again, and then also the backlighting, but still no display. When I checked for voltage going to the amps on pin 1, my orange leds were not on, and I got no sound of the on/off from the amps. So I'll test pin 1 on the blCk connector and see if I have any voltage now.
