Water pump and plug wires
Old Jan 12, 2017 | 05:21 PM
  #31
dbbd1's Avatar
dbbd1
You should be able to test the secondary (high voltage) side of the coil by going from the center lead (that would normally go to the disty) and one of the other two leads (if you get the wrong one, it will show an open circuit). It should be the one labeled #1 in the above link.
Old Jan 12, 2017 | 07:16 PM
  #32
racefan41's Avatar
racefan41
I would wash it off good and look for cracks in it too. your test numbers could be showing good, but the spark could be grounding out on your motor where it bolts up. with that many miles, that coil body is probably getting on the brittle side.
Old Jan 12, 2017 | 07:24 PM
  #33
dbbd1's Avatar
dbbd1
Indeed, on the high-voltage side, you could have a hairline crack that could short under that high-voltage condition.
Old Jan 12, 2017 | 08:12 PM
  #34
atc250r's Avatar
atc250r
I left my truck at work until Monday, but I know the coil body is split open on the seams. Has been for years.
Is it possible for the truck to still run if I get "no circuit" when testing the top pole to both of the lower pins???
Old Jan 12, 2017 | 08:32 PM
  #35
Are you getting any spark?
Old Jan 12, 2017 | 08:48 PM
  #36
2bit's Avatar
2bit
I put a Standard Motor Products coil on our truck from Rock Auto. Part # for a 1997 is UF97 $28.
If your wires are bad, there could be arcing in the cap. I would put a new cap and rotor on with your new plug wires. New NGK plugs also. With the miles on your truck I would replace the coil also. I do agree that you need to test and find what is actually wrong. Your plug wires shouldn't fail every other year.
Old Jan 12, 2017 | 09:10 PM
  #37
atc250r's Avatar
atc250r
Yeah, it still runs. I've been driving it to and from work every day, 45 miles each way. It doesn't idle well though. CEL just came on again yesterday.
Old Jan 12, 2017 | 09:26 PM
  #38
atc250r's Avatar
atc250r
Would anyone hesitate to buy this one?
http://www.ebay.com/itm/CHRYSLER-OEM...xYTJpY&vxp=mtr
Old Jan 12, 2017 | 09:44 PM
  #39
racefan41's Avatar
racefan41
that doesn't look like the one you need (no tensioner pully should be attached to it for a 1500 5.9L to my knowledge) . I paid around $80 for mine '98 5.9 at the stealership.
Old Jan 12, 2017 | 09:51 PM
  #40
dbbd1's Avatar
dbbd1
Originally Posted by racefan41
that doesn't look like the one you need (no tensioner pully should be attached to it for a 1500 5.9L to my knowledge) . I paid around $80 for mine '98 5.9 at the stealership. I've heard good things about Standard Motor Products and probably easier on the wallet
Yeah weird pic.
I bought an Accel coil.
