Water pump and plug wires
Old Jan 17, 2017 | 10:52 AM
  #51
dbbd1's Avatar
dbbd1
Originally Posted by atc250r
Amazon. But Magnecor was the shipper/seller. It took 7 days from the time I bought them, for them to finally ship. That wasn't impressive. $118 for the KV-85's with free shipping.
Thanks.
Old Jan 17, 2017 | 12:46 PM
  #52
atc250r's Avatar
atc250r
Originally Posted by ram-tuff
Your IAC could be the issue for your idle. Might take that off and clean it up.
About 6 months ago, I took it off and thoroughly cleaned it.
Old Jan 17, 2017 | 02:03 PM
  #53
ram-tuff's Avatar
ram-tuff
Well hopefully your new coil will fix the issue. If not, I would check the IAC again and also check the voltages from the TPS. Also make sure the TB is clean as well, this can cause idle issues.
Old Jan 17, 2017 | 02:16 PM
  #54
dbbd1's Avatar
dbbd1
Make sure that you have an oring or fiber(paper) gasket in place too.
Old Jan 17, 2017 | 06:40 PM
  #55
Or maybe that hard-to-find vacuum leak.....
Old Jan 17, 2017 | 06:45 PM
  #56
atc250r's Avatar
atc250r
I drove it in my garage after work today and the garage smells extremely strongly of gasoline.
Old Jan 17, 2017 | 06:51 PM
  #57
Got a fuel leak somewhere? Don't forget to check the Evap system......
Old Jan 17, 2017 | 07:06 PM
  #58
atc250r's Avatar
atc250r
I gutted my cat back in summer (it was rattling), and after that the exhaust just smelled "dirty". Lately though, the exhaust has smelled a bit gassy. Today was rediculous though. I'll go out and check now if it was raw fuel from a fuel leak (that's what it smelled like), or if it is from the exhaust. The O2 sensors are both OEM, and it never threw a code after gutting the cat.
EDIT: I discovered the fuel leak...on my walk-behind snowblower that also sits in the garage. Wow, do I feel stupid. So ignore the fuel leak issue. Still, I wonder if an O2 sensor is acting up amd causing the poor idle? I'll look into the IAC later tonight...
Old Jan 17, 2017 | 09:49 PM
  #59
atc250r's Avatar
atc250r
Took the IAC out and it looked very clean.
Old Jan 17, 2017 | 09:58 PM
  #60
racefan41's Avatar
racefan41
I think you'll be surprised by the difference after installing the coil. Even after you replace it, it may take a few drive cycles for the o2 sensors to catch up and tell the pcm about the changes. If that coil was bad for long enough, that may have been what messed up your cat.
