no voltage to 2002 dodge ram 1500
Old Dec 29, 2016 | 03:20 PM
Ronc123's Avatar
Ronc123
Default no voltage to 2002 dodge ram 1500
Need help please. I just removed the complete dash in a 2002 dodge ram to replace heater core. Put it all back together and now have no battery current to anything, No ignition lights no headlights stop lights, everything is dead, I have batt voltage and all plugs under dash hooked up. I even ran a ground from battery to metal dash support thingking I missed a main ground wire. No voltage at all. Has to be a simple miss but I'm running out of ideas. Any thoughts?
Old Dec 29, 2016 | 05:09 PM
Do you have power to the fuse block in the side of the dash?
Old Dec 29, 2016 | 05:34 PM
dbbd1's Avatar
dbbd1
Blew your main batt fuse?
Old Dec 29, 2016 | 07:48 PM
Ronc123's Avatar
Ronc123
My main fuse box is beside battery and I have power there. No blown fuses
Old Dec 29, 2016 | 08:00 PM
dbbd1's Avatar
dbbd1
And?...
Old Dec 29, 2016 | 08:53 PM
Ronc123's Avatar
Ronc123
All my fuses are located under the hood beside the battery. I do have voltage there
Old Dec 29, 2016 | 09:00 PM
There is another fuse block on the drivers side of the dashboard. Open the door, and there it is. Do you have power there?
Old Dec 29, 2016 | 09:30 PM
dbbd1's Avatar
dbbd1
And most of those are powered with the ignition "on".
Old Dec 30, 2016 | 10:42 AM
Ronc123's Avatar
Ronc123
I wish there was but no other fuse box
Old Dec 30, 2016 | 10:44 AM
It's there. There is a cover over it. No second gen rolled off the assembly line without it......
