RAM 1996 with injection system XXXXXX?
Old Feb 16, 2017 | 06:59 PM
malambotre's Avatar
malambotre
Friends do not abandon me. The casting of the block is: 53020006-360 is or is not Magnum ?, the vin number is misleading 3B7HC2673TM, that I do I put a programmable ecu I already have the injectors port (which place) or a carburetor would have to have an adatador (which ) please help
Old Feb 16, 2017 | 07:31 PM
Wow. I am guessing that english isn't your first language? Whats the rest of the VIN?
Old Feb 16, 2017 | 07:41 PM
Moparite's Avatar
Moparite
53020006-360 This is a magnum block # because it matches one i have on a stand. What heads are on it? It must have LA heads along with the early throttle body injection.
Old Feb 20, 2017 | 06:31 PM
malambotre's Avatar
malambotre
Friends of the North, if it is true my mother tongue, paternal, grandparents and other ancestors all Spanish or "Galician" as we say here in Argentina my English is very bad I finished my secondary school with an average of 6 out of 10 because they were good. Now returning to the RAM the complete number is that
* 3B7HC2673TM175354 * Pardon ....
Old Feb 20, 2017 | 07:06 PM
malambotre's Avatar
malambotre
Dear MOPARITE. I know the history of the first 360 MAGNUM with cylinder head LA the truth is that I look for the casting, but I do not find them. Maybe you could help me on where they are. I would have to lift the valve cover and see only if it is normal because I can not get gasket.
Sorry about the language. If it is difficult, I ask one of my children to do the translation.
Old Feb 20, 2017 | 07:54 PM
Ok, now THAT is certainly confusing........ I got a build sheet for your truck... There seem to be some contradictions in it.
3.8 Additional Gallons of Diesel
Followed by:
5.9L V8 EFI LD Engine
and
4-Speed Manual T3340 Transmission
A four speed? Sure, why not.
You won't find anything like that here in the US. It looks like one of the early magnums, (93) with throttle body injection.
Are you looking to get parts for it?
Old Feb 28, 2017 | 07:08 AM
malambotre's Avatar
malambotre
English is not my native language, hope can you understand me.
Motor magnum: yes
Transmission: Tremec T334: yes
Heads?
In the AR, we produce and use small engines. For example, the RANGER is 3.2 lts and the AMAROK (W) is 2.9 lts TOYOTA 2.4 lts (D)
In AR, the experience with V8 engines is null.
The RAM is imported from Mexico (5.7 Hemi and the diesel version). My problem is the lack of experience in those engines. I am seeking advice on what to do to replace the original ECU.
I have two alternatives:
1) A programmable ECU and use the injection system, in that case, which one do you recommend? MegaSquirt, Haltech, some other alternative more economical or which one?
2) A carburetor: I have the OM distributor with HALL we add an ignition type MSD; which carburetor model do you recommend?
Sorry for asking too many questions.
Looking forward to hearing from you.
Old Feb 28, 2017 | 09:15 AM
Did the original ECU fail? Going to carb might be easiest.....
Old Feb 28, 2017 | 10:46 AM
dbbd1's Avatar
dbbd1
Off Topic...
Where or what is the AR?
Old Feb 28, 2017 | 11:09 AM
Argentina?
