Intermitting idle fluctuating and stalling issues
Old Jan 8, 2017 | 12:05 AM
97dodgeram5.2l's Avatar
97dodgeram5.2l
Default Intermitting idle fluctuating and stalling issues
Hello
I got a 1997 dodge ram 1500 5.2l and when engine is cold sometimes when i get on and off throttle the idle drops rereally low like250 and picks up and sometimes keeps droppi g to 0 and even dies .
When at operating temp it drives fine most the time but somwtimessomwtimes surges at light throttle at speeds higher tham 40. Let idle stops or get on it it stops..
Idles surges up and down at 250 and 500. And at 1000 but just fluctuates a hair
Cleaned tb and new tps and iac reset computer with no luck no check engine light and all problems are Intermitting. Not sure wer3 to look next ne3d to get scanner with live data
WWill make some videos to better show symptoms
Old Jan 8, 2017 | 10:22 AM
What brand IAC? Our trucks really don't care for aftermarket parts in critical locations.....
Welcome to DF!
Old Jan 8, 2017 | 10:56 AM
97ramrod1500's Avatar
97ramrod1500
Like heyyou said, our trucks are pretty picky with the aftermarket sensors. They seem to be hit or miss. When I had my 97 1500 I went through 3 aftermarket IAC solenoid before I finally just went to a Chrysler dealer and bought a oem molar one. My symptoms were identical to yours and the molar solenoid solved the issue
Old Jan 8, 2017 | 11:58 AM
97dodgeram5.2l
I got the cheapest iac oreilly. masterpro a bad brand ? Got the cheap tps sensor to
Old Jan 8, 2017 | 12:23 PM
That was a bad plan. Using cheap sensors only invites mysterious problems.......
Old Jan 8, 2017 | 06:09 PM
97ramrod1500
If you can return both and take a trip to your nearest Chrysler dealer. Get mopar brand sensors. Your old sensors cleaned would probably be better than those new cheap ones.
Old Jan 8, 2017 | 06:53 PM
97dodgeram5.2l
Not sure if they will let me but will lookfor receipt i know i still got the old parts
Old Jan 8, 2017 | 08:25 PM
97dodgeram5.2l
Do these trucks come stock with holleythrottle bodys or is that aftermarket.that is wjat it has and old tps was to
Old Jan 8, 2017 | 10:22 PM
97ramrod1500
Yes The Holley throttle body is the stock one
Old Jan 12, 2017 | 12:46 AM
97dodgeram5.2l
My old iac seems like pintle wont stay in and im quite aways from dealer so at moment got aftermarket part on it but i put my old tps sensor on That says holley on it. And it dont wamt to die when cold even when i snap throttle AND ISNT SURGING like it was so im happy for the moment but like i said it was intermittten when and if it starts acting up ill get new mopar iac
