I built a hot engine, but she states P0172...
Old Jan 10, 2017 | 09:06 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Originally Posted by mda8569
Only from old habits, the first thing I think of when someone says there custom built 5.2 or 5.9 magnum isnt as impressive as they thought it was going to be, automatically, I think.....fuel sync
You, my friend, brought up another problem. I drove my rig to a buddy with a snap-on diagnostic tool. As a favor, he plugged in and tried to help me dial in the fuel sync. But it was all over the place! I was burning myself over this engine and we couldn't set it! She ran WAY worse afterward. I left, limped her home, then borrowed a ride to the pick n pull. I grabbed the plugs from both sides of the cam sensor, created a pigtail plug-in between the harness and the distributor with alligator clamps for my voltmeter. I dialed it in(with the engine off, turning the crank till I got a signal at I think 17 degrees?), as best I could. That's what I'm running now....
Old Jan 11, 2017 | 08:39 AM
Is the distributor installed properly? Plug wires indexed to the correct spot on the cap? How is your timing chain?
Old Jan 11, 2017 | 02:06 PM
mda8569's Avatar
mda8569
Originally Posted by johnnyrocket5363
You, my friend, brought up another problem..
LOL, I'm sorry bro, its just I remember guys having problems with tuning these engines properly without a gd expensive scan tool! But it sounds like you have it pretty close, so idk, good luck
