ABS Light - 95 1500 4x4
Old Jan 11, 2017 | 09:26 PM
sjohns45's Avatar
sjohns45
Default ABS Light - 95 1500 4x4
I recently picked up the truck and working out a few old truck kinks.
What can cause the ABS light to come on and stay on?
My assumption is a faulty circuit between a control module of some sort (maybe PCM?) and the ABS sensors @ the wheels. If this is the case, is there a particular range of resistance the sensors should have to keep from throwing a light?
Thanks,
Mike
Old Jan 12, 2017 | 12:40 AM
dbbd1's Avatar
dbbd1
I would start with the ABS sensor in the rear axle. I assume that you only have rear ABS, not 4 wheel.
Old Jan 12, 2017 | 09:43 AM
RWAL, or 4WAL?
Old Jan 12, 2017 | 11:14 AM
sjohns45's Avatar
sjohns45
I haven't pulled the wheels off yet but I believe just RWAL; I don't see any wires around the front wheel.
Any clue wat wat resistance across sensor terminals should be?
Thanks
Mike
Old Jan 12, 2017 | 11:15 AM
Just replace the rear wheel speed sensor then. 99% of the time, on the RWAL trucks, that's the problem.
Old Jan 12, 2017 | 11:35 AM
dbbd1's Avatar
dbbd1
Thanks
Mike
I think just a few ohms, pretty sure it's just a pick up coil. But, yeah, just replace it. If that doesn't cure your ills, check your wiring to the sensor.
Old Jan 12, 2017 | 01:23 PM
Tboned's Avatar
Tboned
I just changed the rear sensor on my 1996 and ABS/Brake light are still coming on. Checked and none of the fuses are blown. Auto parts store didn't pull any codes with reader. Will check wires next.
Old Jan 12, 2017 | 02:17 PM
Ham Bone's Avatar
Ham Bone
on pre obd 2 units I think the module will just store one code and you have to jump pins to read it.
Generic parts Store sensors sometimes work and sometimes don't. If it doesn't clear itself after a few drive cycles then take it back and either try a new one or get a OEM one.
could also verify the wire isn't chewed up somewhere and grounding out.
Old Jan 12, 2017 | 02:49 PM
dbbd1's Avatar
dbbd1
And you only have rear ABS?
Old Jan 12, 2017 | 03:49 PM
Tboned's Avatar
Tboned
Yes, I'm just like the author.
