Grinding noise after 10mph
Old Jan 22, 2017 | 05:23 PM
Nick.O's Avatar
Nick.O
Default Grinding noise after 10mph
Grinding noise only after say 10 mph. Replaced: rear drum brakes, front brakes, calipers, rear differential pinion bearing, rear driveshaft u joints, transfer case, both front wheel hub bearings.
​​​​​​First heard the noise from the rear. Did driveshaft u joints and differential. Then it now sounds underneath the cab or front end. Replaced transfer case and still there. Other work was done just because of the age.
When I bought the truck it had a clicking noise due to the u joints on the front axles were bad. Went to the junkyard and bought whole axles with good u joints. Never had the issue again.
The noise gets louder as I accelerate and doesn't go away until under say 10 mph or so. It doesn't change when in 4 wheel or 2. Possible front driveshaft u joints or a seal for the front axles? I now have no clue what it could be.
2000 Dodge Ram 1500 Sport 4x4 5.9 liter 360 auto
Old Jan 22, 2017 | 05:52 PM
Need to try and localize where the noise is coming from. Given that it doesn't appear until 10mph or so though, is going to make it interesting. Can you raise the rear of the truck, and run it, and get it to make the noise?
Welcome to DF!
Old Jan 22, 2017 | 06:07 PM
racefan41's Avatar
racefan41
Does the rear shaft have a center support bearing?
Old Jan 23, 2017 | 12:23 PM
Nick.O's Avatar
Nick.O
Will have to raise it later on today and see. But I'm pretty sure its it the front not rear.
Also the rear driveshaft is single. Meaning straight with two joints at each end.
