4W Drive lock in issues
I have a 2001 Dodge 1500 5.2L 4 x 4. I'm the original owner and the truck has 161,000 miles. I started having issues about two years ago getting my truck into 4W drive. I would take about 1/4 of mile to get to lock it in. So I installed a new Dorman vacuum actuator amount 8 months ago and it worked for a while and it then totally failed.
I installed a 2nd Dorman actuator pump last month due to the Advance Auto parts warranty. Now it takes about 1 to 2 miles for it will lock in and about 1 mile to get it out of gear.
I replaced most of the vacuum lines amount 18 months and I don't notice any cracks.
Here lately I've noticed a 2nd issue. When I am going up a hill or just hitting the gas a little extra. The fan automatically switches from pushing air out the vents facing me, to pushing air out the vents by the windshield instead. Then, as soon as I let off the gas, cold air returns to the vents facing me.
So I know I have some type of vacuum leak and don't know where to start. I read something about vacuum reservoir?
Any help would be much appreciated.
Shane
Shane
There is a vacuum reservoir under the cowl at the base of the windshield. They seldom fail though.
Did you check the steel lines running along the frame for the CAD? They like to rust out.
Does your cruise control work right? The line under the battery can sometimes get destroyed by stuff dripping off the battery.......
