New guy please help
Old Jan 27, 2017 | 11:34 AM
Dodgeram1279's Avatar
Dodgeram1279
Default New guy please help
Hi guys I'm new to the forum and have a problem my 99 Dodge ram 5.2 4 x 4 feels like I'm pulling a heavy trailer it has no get up and go I don't expect it to be a hot rod but I know what has more than what it's given me now my TPS sensor is reading 12% on idol and 86% at full throttle. From what I can gather the TPS supposed to rain around six at idle and 100% at wide open throttle and I could be wrong put a new TPS sensor on there and seeing results any help would be appreciated
Old Jan 27, 2017 | 11:39 AM
Have you checked the plenum? Last time it was tuned up? Converter tested for blockage?
Old Jan 27, 2017 | 11:43 AM
Dodgeram1279
Brand new motor 100 miles on it bought it as an unfinished project has fresh trans fluid atf +4 and new governor pressure sensor and the other one that's next to it
Old Jan 27, 2017 | 01:26 PM
dbbd1's Avatar
dbbd1
New motor but probably a clogged cat
Old Jan 27, 2017 | 01:33 PM
Dodgeram1279
Anyway to check it with out cutting it out? Also I have exshaust coming out of tail pipe if it were clogged would anything come out?
Old Jan 27, 2017 | 02:58 PM
This thread describes how to check for a clogged catalytic converter.
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Jan 27, 2017 | 07:11 PM
Dodgeram1279
I had a mechanic from my work hook it up to a scanner and he said my cat was fine. Would he be able to tell that from a scanner?
Old Jan 27, 2017 | 07:14 PM
Only that the PCM wasn't whining about "cat efficiency"..... and the PCM is easily fooled.
Remove the front O2 sensor. Go for a drive. Does it run better? Then the cat is clogged.
Oh, and: Welcome to DF!
next question becomes: Rebuilt motor??? What went into it? Is it all stock, or were somethings "improved" upon?
Old Jan 27, 2017 | 09:06 PM
Dodgeram1279
All stock from what I was told. Do I take the o2 sensor before the cat or after? The motor only has 100 miles first oil change has not even been done I bought it as an unfinished project
Old Jan 27, 2017 | 09:13 PM
dbbd1's Avatar
dbbd1
Yes, remove the one BEFORE the cat. It will throw a code, just clear it when you are done.
