Steering wheel replacement
Old Jan 27, 2017 | 10:14 PM
CJSuhr's Avatar
CJSuhr
Default Steering wheel replacement
Somehow I got lucky at the salvage yard and found 2 steering wheels in immaculate condition for my 94 1500. On my way! Came out of a older Dakota, and the other out of a 2 gen Ram. Although this is a pretty easy procedure, I thought I'd just do a right up, and just share my experience.
Tools Needed:
Steering wheel puller
13/16 socket
Ratchet
10mm Deep Socket
Philips Screwdriver
Some pliers
1: Start by disconnecting the battery, as we will be removing the air bag.
2: I reccomend that you wait 5-10 minutes to let any additional power drain from the airbag, before working on the unit.
3: Take your philips screw driver and remove the two screws holding the cruise buttons in, if not equipped, the cover in its place at the bottom of the wheel. Be carful with the little lock clip, as it is fragile and might snap off.
4: Now take your 10mm deep socket, is needs to be deep as the nuts holding the airbag on have studs that stick out kinda far. There are four nuts, remove them, and use some arm strength to turn the wheel, as you can't undo the 2 lower ones without turning the wheel. Have your keys handy, because if you turn the wheel too far, it will lock up, and you have to turn the ignition to unlock it. Once all 4 nuts are removed carefully pull the airbag unit out, and pull on the connector, and then set it off to the side.
5: now take your 13/16 and remove the center nut on the steering wheel.
6: Take your puller kit, which can be rented at most auto parts stores, and intall it onto the wheel and the center hub. And turn away. Should break free quite easily.
7: once the wheel is loose, disconnect your horn connector, and then fish both the horn and cruise and airbag connectors through their respective holes. Be very careful that you don't pull off the clock spring as you fish the wires through as it will want to come off. And Viola, the wheel is removed.
8: now reverse the steps as above and you will have a newish wheel put on. Jut remember that there is one big spring on the wheel so you won't be off or tilted when putting the wheel back on.
9: also when putting the center 13/16 nut back on, torque it to 45 ft lbs as that is factory specs. If you don't have a torque wrench, tight is good.
10: If you put everything back together in reverse, then you are done! Enjoy your newish steering wheel
Bonus pics of the old wheel and new wheels.
Old Jan 28, 2017 | 12:36 AM
2bit's Avatar
2bit
Nice job, thank you. The new wheel looks a lot better.
Old Jan 28, 2017 | 07:32 AM
Tboned's Avatar
Tboned
Thanks for write up!
Old Jan 28, 2017 | 07:48 AM
Dodgevity's Avatar
Dodgevity
Great job!
Now go to Advance Auto and get this particular steering wheel cover. Its the one I use. It will give it a nice modern feel and look, along with keeping it from looking like the old one down the line.
http://shop.advanceautoparts.com/p/a...30b/26983158-P
Old Jan 28, 2017 | 10:11 AM
dbbd1's Avatar
dbbd1
Indeed, very nice write-up.
Old Aug 15, 2021 | 02:21 AM
eeretz's Avatar
eeretz
Hi @CJSuhr I hope you're doing fine.
I'm new to this forum. I found somewhat difficult to find a decent wheel like the one you just swapped. Your old one is better than mine that unluckily got in the hands of some chap with extreme anxiety around the honk buttons and peeled its leather.
That said, would you please sell this old one to me?
Thanks!
Eric.
Old Aug 15, 2021 | 09:02 AM
Moparite's Avatar
Moparite
No need to hunt for good used ones anymore, You can get new leather that matches the original. Contact them if you have a 94-97 as the 98 and up is pictured. "Make sure your wheel looks as in pictures and if it does not, contact us prior to ordering."
https://www.redlinegoods.com/Ram9402...saAr7QEALw_wcB
Old Aug 15, 2021 | 10:31 AM
Thomas bridges's Avatar
Thomas bridges
Thanks!
Eric.
hey eric I got the exact one id be willing to sell. Let me know
