lef blinker light dim, dashboard light for left blinker stays on
Old Jan 29, 2017 | 12:32 PM
fluffytruck's Avatar
fluffytruck
Default lef blinker light dim, dashboard light for left blinker stays on
I have replaced both the blinker fuse the left head light fuse the flasher and the light bulbs. I for the love of me can not figure out why the left blinker is very dim i cant even see it blink and on the dash board the left turn signal light stays on even if the blinker is off. Any help will be greatly appreciated.
Old Jan 29, 2017 | 12:35 PM
fluffytruck
I should also note that all the other lights including hazard lights work fine even the left side head light works fine its just the blinker is very dim
Old Jan 29, 2017 | 12:45 PM
fluffytruck
ok so the bottom coil of the light bulb that i guess gives the brightness is not getting voltage or something because its not blinking. Any idea on how to fix this is it a socket issues or a fuse somewhere that i don't know about.
Old Jan 29, 2017 | 12:54 PM
dbbd1's Avatar
dbbd1
What year is your truck?
Old Jan 29, 2017 | 12:56 PM
fluffytruck
2001 dodge ram 1500 4x4 v8 5.9
Old Jan 29, 2017 | 04:08 PM
xjarhead69's Avatar
xjarhead69
Do the reverse lights work? Do you have Trailer harness? Make sure its not corroded.
Are all the sockets free of rust?
Dave
Old Jan 29, 2017 | 05:01 PM
Ramman18's Avatar
Ramman18
How about the turn signal switch? Aka multi-function switch. If flashers work and you've replaced bulbs, relays and checked sockets, I'd go there next.
http://www.rockauto.com/en/moreinfo....366590&jsn=470
Old Jan 29, 2017 | 06:44 PM
dbbd1's Avatar
dbbd1
Remove the left front turn signal bulb. Does the rear work normally? Put the front back in and remove the rear. Does the front work normally?
Standing by...
Old Jan 29, 2017 | 06:47 PM
dbbd1's Avatar
dbbd1
And you can also try to tilt the steering wheel up and down while testing. The wires in there are prone to breakage.
Old Jan 29, 2017 | 09:52 PM
Clean the grounds.
