Hello could someone please help
hello I am new here and I was thinking about doing a 318 to 360 swap. I understand they are pretty similar but my problem is, is that the 360 is a 1974 and my truck is a 1997, how much difference does the year make and what major steps would I have to take to do this swap? If someone could give me any insight that would be much appreciated
For starters you will be swapping a carbureted engine into a fuel injected truck... That in itself is a headache if you plan to use the stock gauges and all and converting everything...
But if youre just gonna run a carbureted engine in there stock and eliminate all the bells and whistles one wire will make it run.
Youd be better getting a 360 for that year and swap it in and just basically change the PCM ( you can usually pull the one for that motor from the same truck if its there, otherwise you can buy one online between $100-$600
Really no "easy" way to swap that 74 into it and use the stock connections
NOW IF you do that, make sure to rebuild that plenum before installing it, That is one major cause of failure in these motors when that gasket goes. vacumme leaks, oil consumption, power loss, pinging... just to name a few
Your 74 360 is a LA motor and the truck has a magnum. No mount for the crank sensor on LA motors so you really can't do it easily. That is if you where planning on keeping it fi. Do what Sonocativo suggested it's the best way.
From what motor LA or magnum? The magnums have different intake bolt configurations than the LA style. Look at the link it will explain the differences.
http://www.magnumswap.com/using-la-parts-on-a-magnum/
Will the 318 heads and intake bolt on the 360?
