transmission ?
Old Feb 12, 2017 | 11:16 AM
rapshee's Avatar
rapshee
I'm looking for an impact torx set. Only set Ive seen so far only goes down to a t40.
Old Feb 25, 2017 | 09:32 PM
rapshee's Avatar
rapshee
Just to give an update... I tore the trans down, cleaned and inspected everything. The only hard part that I needed to replace was the overdrive piston retainer between the two case pieces.
I also started the rebuild. I got the overdrive section reassembled and plan to get some more done tomorrow.
Old Mar 9, 2017 | 07:49 PM
rapshee's Avatar
rapshee
I finished rebuilding transmission and installed transgo jr shift kit. Just need a good day to swap over and see if I did good
Old Mar 10, 2017 | 10:07 AM
Tboned's Avatar
Tboned
Fingers crossed for you
Old Mar 10, 2017 | 11:23 AM
Tboned's Avatar
Tboned
Old Apr 15, 2017 | 10:22 PM
rapshee's Avatar
rapshee
just wanted everyone to know that I finally got the rebuilt transmission in and everything is working great.
the old tranny had graphite for fluid but still seemed to shift fine in the three gears it had.
Old Apr 16, 2017 | 09:01 AM
Awesome.
Old Apr 20, 2017 | 10:04 PM
5.7Beastly's Avatar
5.7Beastly
Yes there is an aftermarket pan with a drain plug. It is about $30 at napa and worth every penny!! What a pain that pan is.
