Engine bay cleaning
Old Feb 3, 2017 | 10:47 PM
CJSuhr's Avatar
CJSuhr
Default Engine bay cleaning
So this may be weird, and it if for me as I normally let the dust collect where it sits in the engine bay, but my 94 is friggin caked. It's got about 140 thousand miles on her, and for about half of that I guess the valve covers were leaking. On top of some leaky valve covers, my grandpa is a farmer, you can see where I'm going, gravel roads. And it is just caked like no other. I've seen some pretty nasty 1950s mower engines, and this is worse. Between the valve covers and the intake, I guess you could call it The Valley, not very good with the technical jargon, but anyway, I got about a quarter inch deep collection of soot, or filth.
Now I ain't looking for it to be a show engine, but I want it clean enough to where I can work on it. Clean enough to where I can fix something, without the first tool I use is the brake clean, if you get me.
I want to degrease and clean as much as possible, and plan on using the garden hose, but what to avoid? I know to put a bag over the cap and rotor, is there anything else I should know to avoid? (Don't have a air compressor, just a shop vac and some hose water). Any suggestions on good degreasers you have used?
Any help appreciated, as up next is timing chain and water pump. Thanks!
Old Feb 3, 2017 | 10:52 PM
CJSuhr's Avatar
CJSuhr
Oh just remembered, the pcm, and alternator, and battery need covered too. Am I missing anything else?
Dodgevity's Avatar
Dodgevity
Cover Alternator, fuse box and any other sensitive electronics with plastic bags. Spray degreaser on a warm engine and let it sit for about ten minutes. Scrub brush anywhere you desire, then hose off. If you have leaf blower, blow it off. Drive soon after to dry it.
Old Feb 4, 2017 | 01:03 AM
adukart's Avatar
adukart
Put some spark plug grease on the plugs or pull the heat shield cups around them. I have had many issues with that.
Old Feb 4, 2017 | 10:05 AM
Moparite's Avatar
Moparite
Rent a pressure washer! It will clean the crud way better than a spray cleaner and a garden hose. You can also use them at some car washes but make sure you don't spray the sensitive stuff (cover it).
Old Feb 4, 2017 | 12:21 PM
Careful with the pressure washer, it has the ability to push water right thru weak gaskets.
Old Feb 4, 2017 | 07:14 PM
CJSuhr's Avatar
CJSuhr
That's what I don't like. I've never been a fan I feel pressure washers, even on washing the body. I just go by the rule, if you can't stick your hand in front of it, don't use it.
If it's in the 40s tomorrow I'm going to do it. I'll post some pictures if i do.
Thanks for the help!
Old Feb 5, 2017 | 12:44 AM
racefan41's Avatar
racefan41
if it's that bad, I would get in there with flathead screwdrivers, putty knife, and whatever other tools to get as much of the buildup off before you sprayed anything on it. I've heard good things about Zep degreaser products, but personally never used them. any brand would probably work alright even if you have to do it a couple/few times.
