Cam?
Old Feb 8, 2017 | 08:06 PM
Dray1993's Avatar
Dray1993
Default Cam?
what type of cam comes stick in a 1997 dodge magnum 5.2
Old Feb 9, 2017 | 07:44 AM
Stock stick.
Old Feb 9, 2017 | 09:47 AM
A compromise cam, between fuel economy, and everything else..... Changing to 1.7 ratio roller rockers is a quick and easy power boost. Changing the cam will likely require changing a lot of other stuff too, and also want a custom tune to run right.
Old Feb 9, 2017 | 04:03 PM
Dray1993's Avatar
Dray1993
Well I'm changing the heads so I figured I would do the cam as well but I know that some vehicles come stock with a roller cam but I'm not sure if the 90s 318 magnum has a roller or hydraulic flat tappet cam
Old Feb 9, 2017 | 05:02 PM
Hydraulic Roller.
Better budget in a tune for that as well though.
Old Feb 9, 2017 | 06:21 PM
Dray1993's Avatar
Dray1993
I am, and I found out that the 318 magnum has a hydraulic roller cam, so any ideas on where to get a good 264/272 with a 110 degree lobe?
Old Feb 9, 2017 | 07:35 PM
fj5gtx's Avatar
fj5gtx
I'd reach out to comp cams, tell them what you have (component wise) and give them an idea of your goal.
http://www.compperformancegroupstore...CAMRFHRCC92-02
Old Feb 9, 2017 | 07:59 PM
Yep. What he^^ said. Good Plan.
