Engine turns over wont start
Old Feb 10, 2017 | 11:39 AM
oldtruck's Avatar
oldtruck
Default Engine turns over wont start
Having problems with a 99 ram 360 that turns over but wont start. Stalled out suddenly on the road, and rotates but wont start. I've got spark, I can hear the fuel pump whirr when I turn the ignition on. My next step is to get a fuel pressure tester. Any Ideas?
Old Feb 10, 2017 | 11:48 AM
dbbd1's Avatar
dbbd1
if you have spark then start with the cam position sensor in the distributor, otherwise, I'd go with the crank position sensor.
Old Feb 11, 2017 | 08:46 AM
oldtruck's Avatar
oldtruck
Fuel pressure is good (50psi). Sounds like a good idea. I will test the cam sensor and crank sensor
Old Feb 12, 2017 | 08:39 AM
oldtruck's Avatar
oldtruck
changed out cam sensor with known good one. Still won't start. I will try the crank sensor.
Old Feb 12, 2017 | 09:03 AM
If you are getting spark, the crank sensor is doing it's job. Are you getting injector pulse?
