Park sensors?
Old Feb 13, 2017 | 05:23 AM
mark broad's Avatar
mark broad
Default Park sensors?
Ok, I've got an 01 ram 5.9. Tranny has been replaced then rebuilt. Added a shift kit, pressure switch, trans cooler ( another one ) now when I put it into park out won't turn over/start. Is there a sensor or just a linkage issue?
Also thinking about a 68rfe trans. swap. Possible?
Old Feb 13, 2017 | 09:07 AM
Welcome to DF!
There is a neutral safety switch on the trans, right below where the linkage connects. I think it's a 3 pin connector?
Will the truck start in neutral? If it will, might just be a linkage adjustment.
Old Feb 13, 2017 | 02:07 PM
mark broad's Avatar
mark broad
It will start in neutral it also starts in park some times. So it's a linkage adjustment it needs. Sweet. Thanks much.
Now do you know if the 68rfe transmission will be able to be swaped right over? Read a few things but couldn't tell. I already get 17mpg at 72 mpg but extra gears would be nice.
Old Feb 13, 2017 | 03:26 PM
Nope. It won't bolt to the engine, and the PCM would have no clue how to run it.
