46rh-re 2wd/4wd
Old Feb 17, 2017 | 09:37 AM
Soup is on.'s Avatar
Soup is on.
I called the dealer and it does indeed have the 46re
Old Feb 17, 2017 | 01:27 PM
That makes it kind of easier.....
Old Sep 21, 2019 | 10:59 AM
Jason W's Avatar
Jason W
Originally Posted by Soup is on.
I realize that, my apologies. But it just so happens that my 3rd gen has the same trans as the 2nd gen. So really my question could be answered here. But I'll gladly take my inquiries to the appropriate forum if that'll make you feel better.
Transmission's will fit on the 2nd gens up to 04. Your 2wd will work in the 4wd with the tail swap but as stated before, you must have the correct shim. There is a tool to buy so you can measure or you can use a depth micro like I did.
Old Sep 22, 2019 | 07:56 AM
HeikIlm's Avatar
HeikIlm
After two years, OP has probably got his transmission problem solved...
