emissions test fail, couldn't read computer
Old Feb 15, 2017 | 05:14 PM
ruth52ford's Avatar
ruth52ford
Default emissions test fail, couldn't read computer
Person at emission testing said he could not read the computer on my 96 Dodge Ram truck. He said check the fuse to the ECM. Can not find in the diagrams an ECM fuse.
Old Feb 15, 2017 | 05:48 PM
If the truck starts and runs, the ECM is most certainly getting power. Likely just a problem with the OBDII connector. Will the cheap parts store code readers talk to the PCM?
Old Feb 15, 2017 | 08:33 PM
frankie_b_jr's Avatar
frankie_b_jr
If the IOD fuse has popped, it will keep the obd stuff from communicating. It's the one with the cover on it in the fuse block on the dash.
I remember another fuse causing the same issue with the obd port, but I don't remember which one. Good luck and happy hunting.
Old Feb 15, 2017 | 08:45 PM
primem's Avatar
primem
if the scan tool will not power up; check for power at pin 16 of the data link connector. this pink wire should have battery voltage at all times. If no power, check fuse 17 in the fuse block
if the scan tool powers up but will not communicate with the ecm, check the communication lines pins 6 & 7 of the dlc for voltage.
Old Feb 15, 2017 | 09:21 PM
BigGreenRam's Avatar
BigGreenRam
Check cig lighter fuse
Old Feb 16, 2017 | 12:52 AM
brian102's Avatar
brian102
nevermind... i found it. long day...
