'97 headlight
Old Feb 25, 2017 | 08:20 AM
madmikesmech's Avatar
madmikesmech
Default '97 headlight
The headlights on my '97 ram 1500 are yellowed and perform poorly.
What are better the "crystal clear" lens's or the replacement that are like the original with like "defuser.glass" like lens's?
Both of the replacement units are aftermarket
Thank you in advance!
Mike
Old Feb 25, 2017 | 09:23 AM
I just got the stock replacements from AM-Autoparts.com. They were 65 bucks for the pair, and came with bulbs. (even though they say they don't....) I had already purchased bulbs though, so, those just became spares. I also installed the 'heavy duty headlight harness' from LMC truck. Once the headlights were aimed, the light is MUCH improved over the old stock housings. (one was ok, the other was severely yellowed, and collected a fair bit of moisture in it....)
Old Feb 25, 2017 | 10:05 AM
madmikesmech
Thanks Hey You, I'm having no issues EXCEPT the yellowed lenses. how does that LMC truck harness work? Is it larger gauge wire? UnregisteredUser, also mentioned that harness as an upgrade, I think I will do a little detailed research on the harness and relay install.
great forum and members!!! thank you
Mike
Old Feb 25, 2017 | 01:55 PM
Mike
The current wiring runs all the power thru the switch in the dash. (it controls the ground side of the circuit.) So, there are some limitations there. The LMC harness changes things around, so the switch just controls two relays. (high, and low beam) With the harness, the headlights are powered directly off the battery, giving them MUCH better power flow, hence, brighter light output. The harness is dead simple to install. I only had to drill one hole, for the passenger side ground wire. (there was a convenient ground already there on the drivers side.) It's about as plug and play as you can get, and the price is reasonable. (like 27 bucks, but, gotta add shipping to that, so, a bit over 40 bucks total.)
Old Feb 25, 2017 | 02:51 PM
madmikesmech
Nice' I got on the AM-Autoparts.com, and could not register therefore, I could not view the site good. I took the chance with these from eBay http://www.ebay.com/itm/CHROME-HOUSI...3267#vi-ilComp. I will get on the LMC site and look into purchasing that wire harness relay set up
Old Feb 25, 2017 | 03:11 PM
Those look a lot like the ones I got. Even though it says "no bulbs", don't be surprised if you find them in there.
Changing them can be fun. I had to loosen up the bumper on the 98, let it drop down, and then it was easy. Getting those bolts was not.
Old Feb 25, 2017 | 04:53 PM
madmikesmech
Yeah, I read your post on how you went about the change out! Well regardless of the hassle I must do it asap! My.headlights are terrible, I live in a rural area, deer, and other critters roam out into the roads at night, and it's real easy to "overdrive" the headlights the way she is.
I thank you and the others on this great forum for all the help full info!
I think I'm going to run the 9004 Sylvania Silver Stars Halogens, IF those assemblies do not come with bulbs
Old Feb 25, 2017 | 05:37 PM
Torxhead's Avatar
Torxhead
FWIW, I still have the oem lenses, that are still in pretty good shape. I do polish them with Meguiars PlastX lens polish. Although replacing them would be less elbow grease in the long run. I did have a light bulb blow from moisture in the housing once, so I drilled a 1/4" vent hole in the top of the housing. I has been that way with no issues for years since.
Old Feb 26, 2017 | 06:54 PM
UnregisteredUser's Avatar
UnregisteredUser
I had the same experience, but the bolts weren't challenging because the truck's not rusty. From the looks of the Ranch Hand I won't have to drop it out of the way next time and I'm hoping it's so because the Ranch Hand is one heavy mother humbler.
Old Feb 26, 2017 | 06:57 PM
It wasn't because they were rusty, its simply because of where they are.
