Power Sliding Window
Old Feb 28, 2017 | 02:49 PM
dpalo's Avatar
dpalo
Default Power Sliding Window
Does anyone know of some type of conversion kit or something that i can install to make my sliding back window power? I have a 2001 Ram 1500 sport
Old Feb 28, 2017 | 03:07 PM
I have one in my 98, but, I do believe it is aftermarket. Not sure if you can even find them anymore. LMC truck might be a good place to look.
Old Feb 28, 2017 | 07:05 PM
dbbd1's Avatar
dbbd1
I converted my manual window to a power window in my Tacoma, but it only has a single pane that slides, not the split panes like the dodges.
https://www-dot-tacomaworld-dot-com
/threads/converting-sliding-rear-window-to-power.64816/
Copy and paste to two lines together and put the "." where it is supposed to go...
It was rather easy to do. The reason I did it was because my Tacoma is a double cab and I could not easily reach the window. My dodge is a single cab so I really don't need this mod. However, I can see how it could easily be done. Use two actuators, either electrically connected together or with individual switches. Same effect. The part number should work or use a ram with less "throw" as the dodge sliders do not individually open 12" each.
Old Mar 2, 2017 | 04:50 PM
dbbd1's Avatar
dbbd1
Or maybe you can do something with this...
https://www.instructables.com/id/Mak...ider/?ALLSTEPS
