Transmission replace flex plate won't start
Old Mar 13, 2017 | 09:51 PM
wildcats03's Avatar
wildcats03
Default Transmission replace flex plate won't start
I got a 98 dodge ram 1500 5.2. I replace the flex plate in it now i cant get it to start . Its got no fire . Could i have moved the crank shaft ps or unplug something
Old Mar 13, 2017 | 10:01 PM
Probably damaged the crank sensor pulling/installing the trans. It's kind of a pain to get to, but, you are going to have to pull it, check it, and make sure none of the wiring harnesses got pinched between the engine and trans.
Welcome to DF!
Old Mar 13, 2017 | 10:08 PM
wildcats03's Avatar
wildcats03
Thanks that is what I was thinking
Old Mar 13, 2017 | 10:17 PM
Bring your arm with three elbows..... The crank sensor is a major pain. In more than one sense of the word.
Old Mar 13, 2017 | 10:24 PM
wildcats03's Avatar
wildcats03
I found the cps on the back of the block what or where does it plug in to
Old Mar 13, 2017 | 10:41 PM
AtomicDog's Avatar
AtomicDog
The crank sensor bolts to the block and plugs into the wiring harness via an unmistakable plug-in connector.
Old Mar 15, 2017 | 06:53 PM
wildcats03's Avatar
wildcats03
Thanks everyone i got it running it wsa the crank sensor. I took the wheel n fender linin5out n cut some of the sheet metal out of the way luckily i had it on a lift it was easier to get to that way
Old Mar 15, 2017 | 07:31 PM
Did it have a bad experience with the trans R&R?
Old Mar 15, 2017 | 08:11 PM
wildcats03's Avatar
wildcats03
Not sure what you are asking
Old Mar 15, 2017 | 09:25 PM
dbbd1's Avatar
dbbd1
Did you give it a boo-boo while you were messing with the flexplate?
