1994 Ram 1500 5.2L 4X4 Cold engine hesitation
Old Mar 13, 2017 | 11:24 PM
Scott Taylor's Avatar
Scott Taylor
Default 1994 Ram 1500 5.2L 4X4 Cold engine hesitation
Hey There, I have a 1994 Ram 1500 5.2L when it is cold outside and I start the truck it idles rough and hesitates but does not stall if I drive it after starting it bogs down upon acceleration and it back fires, when the engine warms up it runs great. When the temp outside is warm the truck has no issues. The battery is putting out over 14amps and I changed the upstream O2 sensor there is no downstream O2 sensor never had one. Please help me
Thanks
Scott
Old Mar 14, 2017 | 08:16 AM
What temp does the PCM think the engine is at cold start? (need a scanner for that one.....) Any codes?
Welcome to DF!
Old Mar 14, 2017 | 11:13 AM
Scott Taylor
Thanks for the reply
the outsidetemp is cold between 25-40 no warning lights are on
Old Mar 14, 2017 | 07:14 PM
Yeah, but what temp does the PCM think it is? Coolant temp sensor has quite a few failure modes that won't set a code.....
Old Mar 14, 2017 | 11:05 PM
Scott Taylor
Today st 310pm left work truck ran with no issues. So what do you think is the problem
Old Mar 15, 2017 | 08:47 AM
The intermittent ones are always the most fun. You are likely going to have to do some data logging, in order to see what is going wonky when it doesn't want to run right.
Old Mar 15, 2017 | 11:10 AM
Scott Taylor
This morning temperature here 27 and it really acted up I would say major hesitation when in drive and accelerating. When I'm accelerating it's like bogging down and you can hear it backfiring then as it got warmer the engine started running fine with no problems. It's very frustrating I need some pinpoint help here
Old Mar 15, 2017 | 11:50 AM
You need to find out what various sensors are reporting when the engine is cold, and what changes as it warms up. There are several sensors that could cause you issues, as could slightly low fuel pressure.
How long does it need to run before it straightens out?
Old Mar 15, 2017 | 03:16 PM
Scott Taylor
Thanks for the reply and to help so far I'm showing no codes being a 94 Dodge truck it's OBD one I don't have a scanner it maybe less I half a mile to a mile before it starts to run right it never stalls. Right now I am leaving work it's running fine temperature out here is about 38° On an OBD one how do you get it to show codes is there a way to turn the key numerous times to get the check engine light to flash stuff
Old Mar 15, 2017 | 03:37 PM
I think if you cycle the key three times, (but, not start it) it will flash codes with the CEL. But, if it isn't on... you may only get a code 12.
It starts running better about the time the PCM starts paying attention to the O2 sensor... so, could be low fuel pressure, (easy to check, parts store should have the gauge you can borrow) or maybe IAT sensor.....
