Transmission Swap
Old Mar 28, 2017 | 11:29 PM
Mad_Mike1972's Avatar
Mad_Mike1972
Default Transmission Swap
Quick question, I have a 97 Dodge Ram 1500 5.9 4x4.. The Transmission has gone out, not completely, 1st and Reverse went out.. I have found a 2000 Durango.. Would the Transmission work out of that vehicle?
Old Mar 29, 2017 | 07:48 AM
Depends on the engine in the Durango.
Old Mar 29, 2017 | 12:04 PM
dbbd1's Avatar
dbbd1
4wd or 2?
Old Mar 29, 2017 | 12:34 PM
Mad_Mike1972
Default Transmission swap
Both are 4wd
Old Mar 29, 2017 | 06:11 PM
What engine is in the Durango? If it isn't a 318, or 360, then it is quite unlikely it will work.
Old Mar 29, 2017 | 09:21 PM
97ramrod1500's Avatar
97ramrod1500
If the Durango has a 5.2 or 5.9 the transmission should bolt up however it is likely the 42re. If that's the case don't expect it to last real long under a full size truck.
