Shifting problems
Old Apr 9, 2017 | 11:11 PM
wilddmike's Avatar
wilddmike
Default Shifting problems
my 1999 Dodge Ram 1500 with a 5.9 magnum 4x4 has transmission issues and anyone with advice is welcome to chime in. It currently does not shift into second gear until I reach about 2100 RPM then for me to get to third I have to reach about 40mph and let off and then eventually it shifts. Sometimes overdrive kicks in but it's very randomly any advice helps thanks also if it matters it's a extended cab short bed
Old Apr 10, 2017 | 08:11 AM
Start with a fluid/filter change, and a band adjustment. (installing a drain plug in the pan at this point, really wouldn't be a bad idea. ) Also check TV cable, makes sure it moves freely, and is adjusted properly.
Welcome to DF!
Old Apr 10, 2017 | 08:50 AM
wilddmike's Avatar
wilddmike
Thanks for the advice, any info on band adjustment? And yes I am new here just figuring out how to use the forum.
Old Apr 10, 2017 | 09:38 AM
Grab the service manual for your truck from here. Procedure for band adjustment is in there.
Old Apr 10, 2017 | 09:48 AM
wilddmike's Avatar
wilddmike
Thanks I appreciate it
