ECO 85 gas
Old Apr 11, 2017 | 08:21 PM
SgtMoe's Avatar
SgtMoe
Default ECO 85 gas
Ok guys I need ur help...I heard that if u were to mix ECO 85 in ur regular gas...when mix together it boost ur octane way up there....Is this true? guys
Old Apr 11, 2017 | 08:23 PM
Your truck won't run worth a fart on any mixture of E85. As its name implies, it is 85% alcohol. Your PCM doesn't have a clue about the stuff, and doesn't even care for the E10 that you normally run it on. Boost the alcohol content any higher, and you will be lucky if it even starts.
Old Apr 11, 2017 | 09:25 PM
SgtMoe's Avatar
SgtMoe
Copy that brother....Thank u for ur time....
Old Apr 12, 2017 | 09:55 AM
CJSuhr's Avatar
CJSuhr
I found this a few months ago. I've wanted to try it but it's a little expensive for my budget. The gas milage would drop using e85 because it is a higher octane. The higher the octane, the harder it is for the fuel to burn, and the less power the fuel produces. Thus, requireing more fuel to run the engine the same way as it would regular gas. Not sure if it's worth it in money saved because e85 is cheaper, it would balance out because your at the pump more often. Most people who buy it wanna combat big oil. If your up to buying it i love to hear about how you like it.
https://www.change2e85.com/E85-flex-...ev1-jeep-dodge
Old Apr 12, 2017 | 01:25 PM
In all reality, it isn't the octane rating that is the issue. The real issue is, alcohol simply doesn't release as much energy as gasoline when burned. Therefore, you need more of it to produce the same amount of power. Octane is just a measure of a fuels 'tendency' to want to burn. It still carries pretty much the same amount of energy, you can just utilize it differently. (higher compression, more spark advance, without as much danger of pre-ignition. Thus, more power from the engine.)
Given the minor price difference between regular gas, and E85, and the significant hit you take in fuel economy by running the E85, in my view, it simply isn't worth any investment at all to convert to a fuel that isn't that much cheaper, and will likely cost you just as much to run, as regular gas. It would take a VERY long time to recoup that 400 and change you spent to convert...... I think it would be money spent to no good purpose.
Old Apr 12, 2017 | 02:57 PM
primem's Avatar
primem
and if your not flex fuel compatible you should not be running over 10 ethanol. It will corrode the fuel pump, lines and injectors if they are not e85 compatible.
Old Apr 12, 2017 | 06:31 PM
Even the E10 does horrible things to your fuel system. It's one of the things the auto manufacturers have been complaining about for over a decade.
Old Apr 12, 2017 | 10:19 PM
primem's Avatar
primem
i agree.
all the 87 octane pumps where i am all say may contain up to 10% ethanol...hard to get away from it. I run premium in my small engines to try to get away from it.
Have not seen any e85 pumps in Canada ever.
Old Apr 12, 2017 | 11:10 PM
CJSuhr's Avatar
CJSuhr
All the gas I'll ever put in my truck will be e10. Always have and always will. I've never had one fuel system issue related to ethanol. Ethanol just gets a bad rap still from when it was introduced back in the day and was attributed to having a lot of water in it. Ethanol does not have water in it. Only when you let it sit forever does it start to migrate to water and other chemicals. When it comes out of the pump it's 99% alcohol.If it is bad, we'd see a lot more of the older vehicles suffering, because 90% of the population that puts e10 or higher in their car doesn't even know what the It is. They just go with the cheapest option.
I don't know this is more of a rant . I just don't like it when people start hating on ethanol. It supports our economy not the Syrians or such economy. You hear a lot about the Nebraska economy here with it, and at a lot of places it's hard to find gas without ethanol in it. Even priemum. I like it, I'll use it, plain and simple.
Old Apr 13, 2017 | 08:46 AM
I use it simply because I don't have a choice. The nearest 'ethanol free' gas station is over 20 miles away.
One of the issues with ethanol is, it's hydroscopic. It will absorb moisture right out of the air. Gasoline does not.
In case you haven't noticed, I am not a fan of ethanol. The original idea was reduce our dependence on foreign oil, which it didn't. Then, it was to reduce CO2 emissions from fossil fuels, which it doesn't. The mega-farmers love it because of all the government subsidies they get for raising corn for fuel. The general public doesn't much care for it, as all that corn being re-routed for 'fuel production', tends to increase the cost of animal feed, so, food prices go up.
Ethanol really isn't doing the country any favors. A small selection of the population profits from it, but, by and large, it just costs the rest of us more money.
