Rear diff pinion bearing/seal replacement question
Old Apr 19, 2017 | 07:24 PM
Read the procedure in the service manual a few times.
Old Apr 19, 2017 | 09:26 PM
oxymoron29's Avatar
oxymoron29
I have never had to disassemble the diff to get the front pinion bearing off. And I have done a fair few of 'em......
Were they 9.25's? Not doubting your expertise I am just speaking from what I encountered. Whether I was using the old or new bearings in pinion depth trials I had to whack that pinion shift out hard with a sledge each time to press off the front (yoke side) bearing. Made sense to me that they were pressed on, I wouldn't want the inner race spinning relative to the shaft. Experienced the same with the D44.
RJ: I would replace both if you are in that far, cups and cones. The manual also gives a rotating torque for new bearings and a different one for used bearings, so throwing both into the mix would probably not be ideal. BTW you will need the threaded adjuster wrench for working on this axle, if you don't already have it.
