Conversion ujoint for rear axle
Old Apr 27, 2017 | 04:10 PM
sam3293's Avatar
sam3293
Default Conversion ujoint for rear axle
So i was trying to swap out my rear axle on my dodge ram 1500. Since the leaf pack burst, the leaf spring perch on the axle craked and the pinion gearing is shot.
i need to find a ujoint that can fit a 99 dodge ram 1500 driveshaft and attach to a 02 dodge ram 2500 rear axle yoke.
Any ideas which one i should get? Im having trouble figuring it out. Thanks
Old Apr 27, 2017 | 04:44 PM
dbbd1's Avatar
dbbd1
What did you have in there originally, 9.25? What did you replace it with, D60?
Old Apr 27, 2017 | 05:05 PM
That would be my guess.
Old Apr 27, 2017 | 05:55 PM
sam3293's Avatar
sam3293
The truck had a 9.25 originally then i swapped it for a d60 from a 94 2500 but somehow the ujoint fit. The new axle is a d60 from a 02 ram 2500 and the u joint wont fit.
Old Apr 27, 2017 | 06:07 PM
Can you swap the yoke from the 94 axle?
Old Apr 27, 2017 | 06:21 PM
sam3293's Avatar
sam3293
I dont have the yoke anymore i brought it to the scrapyard already. I realize now that was stupid.
Old Apr 27, 2017 | 07:42 PM
renardk764's Avatar
renardk764
Search Combination U-joint. Should be able to find what you're looking for. You may have to find the part number for the your year model truck and the year model d60 you installed.
Old Apr 27, 2017 | 07:48 PM
sam3293's Avatar
sam3293
Currently i think i need a 1330 to 1350 conversion joint but was not 100% sure. So i was seeing if anyone knew which one to use.
