My Kegger Mod
Old May 5, 2017 | 09:24 AM
Yeah, pull the fan, shroud, and radiator, then just lift the motor a bit, pull it forward enough to disengage from the trans, and then straight up. Letting the air out of the front tires to lower the front of the truck makes life a little easier as well.
Old May 5, 2017 | 07:54 PM
Adobedude's Avatar
Adobedude
From what I've read on the Dakota R/T Forums, the Keggar mod is a complete waste of time.
Old May 5, 2017 | 09:48 PM
Basically, all it does is move the power band up a couple hundred RPM.
Old May 6, 2017 | 10:08 AM
Adobedude's Avatar
Adobedude
I was going to do it to my 98 2500 for towing for just that reason, but I found a 2001 24 valve with 97K on it.
Old May 6, 2017 | 11:38 PM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
I cut my runners the same as you are planning on cutting yours. Works fine, but may not be worth the time. I have an unmodified intake and sometimes I think about putting it on the truck as some times i'd like a little more low end torque.
You can pull the motor with the AC condensor in place, just pull the fan, shroud, radiator, and hood.
Old May 10, 2017 | 08:11 PM
CJSuhr's Avatar
CJSuhr
I'd like to keep my low end, so idk. I've read up and many like it, and others don't. I'd rather keep my low end, though I do tow often, I'm not sure how much it would help. And it is also a tedious job. I may look at instead getting a 50mm tb and if I have the money some 1.7 roller rockers instead. As well as some shorty headers. What would you guys think would be the best way to go? A
Old May 10, 2017 | 10:57 PM
AtomicDog's Avatar
AtomicDog
If you are considering taller tires, please consider differential gearing. I'm running 285/75/16 tires with 3.55 gearing and the truck is snail slow from a dead stop. I'm planning to install 4.10 gearing soon in both the front and rear differentials and that will make a huge difference in off the line performance.
