1996 2500 with 5.9 gas, need advanced help
Old May 8, 2017 | 02:08 PM
greg96ram's Avatar
greg96ram
Default 1996 2500 with 5.9 gas, need advanced help
1996 Dodge Ram 2500 4x4 with 360 V8. Will not start. No spark or injector pulse. Cam and crank reference are good. Replaced ECM. Cleaned up grounds. Ignition coil test good. Has new distributor. What am I missing?
Old May 8, 2017 | 02:34 PM
Are you getting power to the coil and injectors? You will only see it for about three seconds after turning the key on, unless the PCM sees the motor turning.
Does the fuel pump prime when you first turn the key on?
Old May 8, 2017 | 02:39 PM
greg96ram's Avatar
greg96ram
Fuel pump does prime. No power at coil.
Old May 8, 2017 | 03:10 PM
Swap the ASD relay for another one. Most of the relays in the PDC are pretty much the same, so, the horn relay should work. (provided your horn works. )
