tv cable removal from trans
Old May 9, 2017 | 07:54 PM
prez-reaper13's Avatar
prez-reaper13
Default tv cable removal from trans
tried searching cant find answer trying to remove tv cable from trans and cant seem to figure it out i loosened what looks like a pinch bolt but cant seem to get it to come off what am i missing thanks
Old May 9, 2017 | 09:33 PM
Where are you trying to disconnect it from, that is giving you trouble?
Old May 10, 2017 | 05:00 AM
prez-reaper13
From the transmission itself
Old May 10, 2017 | 10:08 AM
Strangely enough... I can't find anything in the service manual about R&R for the cable.... Adjustment, yes, but not changing it....
Old May 10, 2017 | 11:32 AM
Tboned's Avatar
Tboned
If its anything like a GM 700R4 you have to drop the pan and disconnect the end of the cable from whatever it attaches to.
Old May 10, 2017 | 11:59 AM
prez-reaper13
ya i looked thru the service manual too didnt see anything so i guess my best bet is to disconect it from tb and leave it connected to the trans
Old May 10, 2017 | 12:23 PM
It should just hook to a lever on the outside of the trans? It *should* come off without too much trouble.....
Old May 30, 2017 | 11:15 AM
prez-reaper13
update on this issue also the tv cable does in fact just pull off of the trans linkage could not tell until i looked at the doner truck from the top was easy lol
