96 2500 trans problem, won't go over 35 mph
Old May 20, 2017 | 01:26 AM
Maxon302's Avatar
Maxon302
With the transmission in drive and the tcase in nuetral should the rear wheels still spin as if it were in 2wd?
Old May 20, 2017 | 08:31 AM
frankie_b_jr's Avatar
frankie_b_jr
With it in the air, there Might be enough resistance in the t-case to turn the tires in neutral. On the ground, there shouldn't be any movement.
Old May 20, 2017 | 09:14 AM
What RPM is the engine at in D, at 35 mph?
Old May 20, 2017 | 10:49 AM
Maxon302's Avatar
Maxon302
Engine rpm is pretty much red lined at 35mph. I'll drop the truck back on the ground this morning and see if the truck moves with the tcase in nuetral.
Old May 20, 2017 | 11:36 AM
Transfer case has to be stuck in low range. That's the only thing I can think of that would explain it.
Old May 20, 2017 | 11:55 AM
Maxon302's Avatar
Maxon302
Put the truck back on the ground this morning, Tranny in drive and tcase in nuetral, it definitely wants to go. So it must be stuck. Sure am glad I didn't go out and buy a new tranny, thank you! So, any thoughts as to getting it unstuck?
Old May 20, 2017 | 11:58 AM
You can either replace it, or, drop it out, tear it down, and see what the issue is. Since it is currently undriveable in any event.... Might just as well drop it out. T-case really isn't complicated, might be a simple fix. Or, at least, obvious what the problem is.
Edit: I advocate dropping it out, as it is a LOT easier to work out, when it is NOT under the truck.
Old May 20, 2017 | 12:04 PM
Maxon302's Avatar
Maxon302
Copy that, I'll drop it maybe watch a few videos on u tube. I appreciate all your advice and help.
Old May 20, 2017 | 12:10 PM
If you don't have one already, grab a service manual for your truck from here. Read up on the process of pulling it out, and tearing it down. Videos are a VERY good idea as well.
