courtesy light switch
Old May 16, 2017 | 04:54 PM
JimDorman's Avatar
JimDorman
Default courtesy light switch
I have a 1994 Ram 2500.
Having a problem replacing the courtesy light switch. I've broken 3 switches trying to get the automatic adjuster to adjust to the right gap. Every time I close the the door (carefully and slowly) with the new switch in place, the switch falls apart. The part I am putting in is Wells Vehicle Electronics switch part no. SW1045. It looks like the one that came out and fits the factory plug.
Has anyone else had this problem?
Old May 17, 2017 | 10:07 AM
Ramman18's Avatar
Ramman18
No, not had this problem. Maybe try a different brand switch?
Old May 17, 2017 | 01:02 PM
JimDorman's Avatar
JimDorman
I've looked for other brands. No luck. Guess I'll do without a dome light for now when I open drivers door.
Old May 25, 2017 | 06:06 PM
JimDorman's Avatar
JimDorman
Default Courtesy Light Switch Solution
I just SUCCESSFULLY install the switch today after 3 other attempts. Here's how I did it in case anyone else comes across this same problem.
Step #1: Throw away the instruction sheet.
Step #2: Use a small screw driver to release the outer locking ring from the inner bezel.courtesy light switch-img_1204.jpg
Step #3: Support the inner bezel (I used a crescent wrench). Use a needle nose pliers to grab below the switch button and push down on the barrel(don't pust on the button itself).(notice the small adjusting notches with a wide notch in the middle) Push the barrel down past the wide notch in the middle of the barrel.
Step #4: Replace the locking ring to it's original place. See step 2.
Step #5: Dig the instruction sheet out of the garbage can and install the per instruction sheet.
