Started fine then then died won't start 94 2500 5.9 gas
Old May 20, 2017 | 07:31 PM
Larson's Avatar
Larson
Default Started fine then then died won't start 94 2500 5.9 gas
I Checked fuel and spark no spark no power to coil plug replaced crankshaft sensor and still no start
Old May 20, 2017 | 07:48 PM
Keep in mind, you will only get power at the coil for about three seconds after key on. Unless the PCM sees the engine turning, there won't be any power there.
So, verify you are getting power to the coil, and the injectors.
Welcome to DF!
