Engine Swap
Old May 26, 2017 | 09:36 PM
93Dak3.9's Avatar
93Dak3.9
Exclamation Engine Swap
So my buddy has a 5.2 Magnum he's selling and there's a 2000 ram with no engine in it. Perfect for a swap! Catch is the previous engine was a 5.9 Magnum. I am wondering if it will fit together with no problem? The truck has a tranny just no motor. I'll also add the donor engine is from a 93 dakota and the Ram is a 01.
Old May 26, 2017 | 09:43 PM
What year is the motor?
Old May 26, 2017 | 10:19 PM
dbbd1's Avatar
dbbd1
Probably a '93...
Old May 26, 2017 | 11:53 PM
93Dak3.9's Avatar
93Dak3.9
It's a 93.
Old May 27, 2017 | 12:14 AM
AtomicDog's Avatar
AtomicDog
That '93 motor was from an ODB-1 computer system and engine harness. The 2001 is ODB-2. It would likely take some creativity to make that swap work properly.
Old May 27, 2017 | 10:00 AM
Mechanically, they are pretty much the same. Just use the intake/sensors from the original motor, on the replacement. Should work.
Old May 27, 2017 | 10:04 AM
dbbd1's Avatar
dbbd1
Uh oh, are you experiencing senior slippage? That's twice in the same thread...
There is no "original" motor. But he can get some from a similar year at the junkyard and/or parts store.
Old May 27, 2017 | 11:10 AM
Senior slippage.... Yeah, yeah. That's it.
That's what I get for posting before my first cup of morning joe........
Old May 27, 2017 | 02:47 PM
93Dak3.9's Avatar
93Dak3.9
So is it relatively easy or should I just go with an OBD-2 engine for simplicity?
Old May 27, 2017 | 06:58 PM
The newer truck isn't going to need EGR, so you could just plug that off. The older motor will have an extra coolant temp sensor as well, which you can just ignore. I don't *think* any of the other sensors report different data... so, as long as they electrical connectors will plug in, you should be ok.
