High Idle going into Park
Old May 30, 2017 | 03:29 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default High Idle going into Park
I've tried a bunch of things. I'm open to retrying things. lol
Symptom:
Idle jumps to 1000ish after going into Park position.
(see video 1)
Have to blip throttle to bring it to nominal idle.
Does not do this when at a stop sign or stop light.
Intermittent frequency. Meaning not everytime going into Park. It will stay normally in the 650-700 idle range as one expects.
Things been done:
On 3rd IAC
2nd TPS, I think
Capped all Vac ports on intake, (except brake booster), no change.
Replaced TB gasket
Swapped MAF
Swapped IAT
Video 1 of Symptom
https://goo.gl/photos/S8pb8rz3a7rq4T717
Video 2 of Vacuum at idle only to rule out vac leak
https://goo.gl/photos/39gzVJe9WgqHzDGCA
Video 3 of Vacuum showing hold at 2K rpm
https://goo.gl/photos/uqCqL76KFBrtVLfX6
2000 Ram 1500, 360
New EQ Monster Heads, stock valves 800 miles so far
1.6 RRs
Thanks for any ideas to try out. Let me know of any other info needed.
Old May 30, 2017 | 04:28 PM
What brand IAC? I had an aftermarket one in my old truck, and it didn't really like it much...
Old May 30, 2017 | 08:53 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
1st replacement was O'Reilly's
2nd replacement is Napa
I have one from another TB, which is factory, to try.
Old May 30, 2017 | 09:00 PM
I would give the factory feller a shot. I took a used one out of an old throttle body I had laying around, to replace the brand new one I had in my truck, and all the stalling and idle problems went away.
Old Jun 1, 2017 | 10:22 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I ended up attempting to measure the TPS voltage. Became unsuccessful b/c I couldn't back probe the harness correctly after determining which was hot and negative.
So I popped in OEM TPS from the spare TB.
Appears to have been RESOLVED.....
Old Jun 1, 2017 | 11:21 AM
Excellent.
